Torque settings for 2012rr.
Discussion in 'Maintenance' started by SteveMac, Apr 17, 2015.
  1. SteveMac
    SteveMac New Member
    doing the chain and sprockets this weekend, anyone know the Torque settings for the sprockets?
    Would have been easier if wemoto had actually sent the correct front sprocket, having to refit the old one, at least it looks ok for 15,000 miles.
  2. PeterT
    PeterT Active Member
    47 lbft for the rear drive sprocket.
    front drive sprocket 40 lbft
  3. sps170373
    I wouldn't fit an old sprocket with a new chain, I'd wait till they replace it
  4. Mr OCD
    Mr OCD Well-Known Member
    New sprockets - old chain - yes
    Old sprockets - new chain - no
  5. PeterT
    Belt drive.... just like the hardleys do... Mmmm
  6. SteveMac
    SteveMac New Member
    I quite agree chaps I would normally only fit a set as i asked for, however I'd already stripped out the chain and changed the rear sprocket before I spotted the wrong part. told them i wanted the correct sprocket ASAP and a new chain again.
    found on another site a 108Nm for the rear sprocket, nowt so far for the front.
    I will have to just crack on, I need to get to work on Monday, and currently doing about 2000 miles a month, who says you can't commute on a blade..
  7. SteveMac
    SteveMac New Member
    Cheers Peter T, sorted cheers folks
  8. travellingkiwi
    travellingkiwi Active Member
    KentBlade and I would never say that :)
    Tho I'm down to 2-3 days a week now as I WFH more.
    H
