Trackday tire pressure
Discussion in 'General 1000RR Discussion' started by kingy3, Jun 18, 2015.
  1. kingy3
    kingy3 Active Member
    hi there I've just bought 09rr with Pirelli supercorsas fitted sc1 front sc2 rear and I'm about 13st can anyone help with correct cold and hot tyre pressures for track day cheers
  2. SimonRR
    SimonRR God Like
  3. kingy3
  4. kingy3
    Cheers mate
  5. Nigelg79
    Nigelg79 Active Member
    Hot pressures: Rear 26PSI, front 30PSI.
    Weight doesn't have much bearing on tyre pressures but suspension does so get that set for your weight.
    Hope it helps.
  6. Muffking
    Found another one of these pics on my PC. Pretty much shows the same pressures as the one posted on the other tyre pressure thread, although I'm finding it hard to find old threads on the new forum.
  7. kingy3
    Thanks Nigelg79 I'll try that
  8. kingy3
    Thanks muffking I'll try that pressure hot cheers
  9. julestys
    julestys Active Member
    Just went to California Superbike school and they say 32 front 30 rear
    worked well for me
  10. stuart_g
    stuart_g Active Member
