Turn signal Relay question
Discussion in 'Other Bikes' started by timmy twoshoes, Mar 21, 2014.
  1. timmy twoshoes
    Is it necessary to fit another relay when fitting LED indicators, or are load resistors the thing to install.
  2. F1reblade
    F1reblade Active Member
    On my RR5 I had to change the relay as well. Which wasn't difficult but just time consuming as it's between the headlights meaning the whole nose came off.
  3. martinowen
    It's a pain in the arse between the headlights and a really stupid idea! I extended my wiring and mine now sits behind the left hand panel, I'm not doing that again!
  4. Tol
    Tol New Member
    I fitted two in line resistors on my Blackbird ( one per indicator,rear) and they seem to work fine.
  5. Barstewardsquad
    Resistors will do the job but be aware that they will get a tadge warm so be careful where you place them.
    Personally I prefer replacing the relay as it is a neater solution.
  6. timmy twoshoes
    The Relay on the 954 is situated under the right hand side of the rear panel, is a right pain to get to as are the indicator wires. So have ordered a pair of extensions
  7. F1reblade
    Wish I'd have done that Martin. Saying that I'm thinking of the Neverland Repsol fairings next month so it'll all have to come apart again anyway. I'm hoping it's straightforward enough to fit, after all if I can arse about with the nose cone as many times as I did then the rest shouldn't be too bad.......should it??? Lol
  8. Haggler ®™
    Haggler ®™ Active Member
    FFS........I know I,m getting old but can someone remind me........where is the relay on a 06 Blade.....thing is.....I replaced it 2 years ago but can't remember WHERE it is.
  9. Barstewardsquad
    Behind LH side fairing, towards the top.
