Tyres...
Discussion in 'Maintenance' started by Blader, Jun 7, 2022.
Tags:
  1. Blader
    Blader New Member
    I've changed to a 190/55 tyre on the rear and found that the tyre fouls on the rear mudguard at the top, its an aftermarket carbon fibre one, has anyone had this issue with the stock mudguard?
    Cheers!
  2. raphael
    raphael Elite Member
    I use the small stock hugger with that tyre size and Never had a problem mate
  3. dern
    dern Well-Known Member
    No but similar in that I couldn't get a tyre warmer between the mudguard and tyre. I added some washers at the faster points on top of the swingarm to lift the mudguard. If you need a neater solution you could measure how many washers it needs to do this and get spacers made up/printed.
  4. Blader
    Blader New Member
    That's what I was thinking it'll lift the hugger so that the side bolt won't line up but I could always fab a bracket and put an extra bolt in
