Venture shield help required !!!
Discussion in 'Mods, Upgrades, Accessories and Products' started by Stevie_d, Mar 31, 2016.
  1. Stevie_d
    Stevie_d Senior Member
    ok , had venture shield put on the bike 2 days ago. Picked the new bike up today noticed 2 small bubbles in the venture shield near the seat. Don't know if it's possible to work them out to the edge of the film. Or if solution is to remove the film piece completely & have it replaced ?
    Also how cab venture shield be removed by myself safely ?
    Any help greatly appreciated.
    Steve
  2. sinewave
    Give it a little Prick with, err a little Prick and all will be well.
  3. 1000rr73
    1000rr73 Active Member
    Try hairdryer, warm it up and push the bubbles down.
  4. blake7
    blake7 Active Member
    as above, pin prick it and push it out. Not uncommon when fitting VS
  5. Stevie_d
    I'll give the hairdryer a go, don't wanna get paint too warm tho.
    If it don't work how can I remove it ?
  6. Stevie_d
    I thought pin pricking would eventually lead to water getting under the film if I get drenched while out one day or washing the bike
  7. sinewave
    Nah, it'll be fine.
    Anyway it'll have gone grey and manky at the edges long before it fails elsewhere.
    Didn't bother with it it on the latest purchases as it was staring to look tatty on the outgoing ZX10 which was only a 64 Plate with 2200 miles on the clock.
  8. sp1n99
    sp1n99 Active Member
    If the bubbles are near an edge you could try warming it with an hairdryer and using the edge of a credit card to try and ease them out.
  9. graemewalker
    graemewalker Elite Member
    Prick it prick it lucky bastard
  10. Stevie_d
    Lol panic over guys , it's done the trick with hairdryer and a rubber pad to move to the edge. I will now get some sleep tonight.
  11. MPJ
    MPJ Active Member
    Had mine on for over 2k miles now, still looks like the day it was applied. I tend to use a spray on detailer wax when cleaning (mostly water anyway !) as it doesn't get trapped under the edges like a normal wax. You can use any products though really if you need to.
  12. graemewalker
    Pics please
  13. Stevie_d
    Just got to fit the hugger Graeme . Had a chaotic day today. Managed to fit me asv levers and 8x6 number plate. Shop fitted the akrapovic gp can.
    Just hoping the Carbon hrc hugger fits ok and there is room for the abs cable, or won't be able to send back to jersey. It'll end up on flee bay .
  14. Stevie_d
    Picking bike up at Honda today
    • Like Like x 7
  15. MPJ
    MPJ Active Member
