We have a couple of ex demo (unused but been on show display) black finish 19 x 20 fixed lever Accossato cylinders @ £130 ea delivered if it's any use?
Interested. Are these plug and play with standard equipment (resivoiur, hoses..) or will I need additional items?
Your std hoses should fit but it's a bit of a waste to use rubber hoses with an Accossato. The std reservoir will work but the fluid hose is smaller, you need 7mm ID hose. For road use you'll also need a pressure brake light switch. We can supply all of this if needed.
I’ve had the same one on my last 2 blades and will be going on the next as it’s the best upgrade you can do mate, great bit of kit and supplier.
Tried to fit this today ahead of the track day next week and it’s not compatible with standard RR7 resivoir. Tried to contact you today but looks like your shut. Will call Monday.
Hi Tom, the std reservoir uses an 8mm hose whereas Accossato uses 7mm, it will fit but is tight. Accossato make a reservoir kit if you need one.
