Wanted.....
Discussion in 'Maintenance' started by Repsol Rob, Sep 23, 2014.
  1. Repsol Rob
    Repsol Rob Elite Member
    A pair of the wire "C" clips that fit into the grooves around the top of Fork leg.......or does anyone know the part number ??
    Forks are 2012 (Showa) but as diameter is the same as RR8- onwards I guess they are all the same.....
    Do you have to fit these...?? I guess if you prefer to drop front a little these get removed anyhow ?
  2. Jamiestrada
    You dont have to fit them they just stop you dropping the forks through the yolks, the ohlins I fitted to the 13 didnt have any I just lined them up flush and bolted it up :)
  3. Ian E
    Ian E Active Member
