Wax or Lube
Discussion in 'Maintenance' started by D16PJM, Jan 12, 2019.
  1. D16PJM
    D16PJM New Member
    What do you use on your chain?
    Pete
  2. nigelrb
  3. Lozzy
    Wurth High Performance Dry Chain Lube.
    Absolutely no fling. Great product.
    If you're winter commuting on the bike though I'd use something a bit more robust just for those months. Not a fan of wax I think it collects crap sticking to your chain.
  4. nigelrb
    Ah, yeah. It was you who recommended Wurth to me.;)
    I hadn't considered the gaining muck effect of the wax on chains. Valid point! Gather no muck on my legs though:D.
  5. Lozzy
    Yeah it was something I hadn't thought about but a few years ago I read an article on the grit and muck it attracts that's then whizzing round on your chain!
  6. raphael
    raphael Elite Member
    Worth do a wax and haven’t had any fling so far also doesn’t get to gunky like some normal wet lube
  7. Lozzy
    I wondered about their wax...was a bit loathe to buy it in case it was messy but might try it if it's not attracting muck too much or flinging :)
    Their lubes great but I'm constantly re applying it in winter
  8. Spygoat
    Spygoat Well-Known Member
    I use Wurth Wax on mine. No slinging so far!
  9. Bikeboy
    Bikeboy Active Member
    Is this post about bikes. Or is it to see how many times we can get Lozzy to write the word LUBE
  10. Selmer50mark
    Selmer50mark God Like
    80/90 gear oil
  11. Lozzy
    If you ask me nicely I'll post of a video up of me saying it verrry slowly :D
    • Friendly Friendly x 1
  12. nigelrb
    Certainly one of the cheaper options.
    Not as silly as it sounds; it's worked in industry for hundreds of years albeit with lower rotation speeds.
  13. CBRGav
    CBRGav Active Member
    Würth dry chain lube for me, always put it on after a ride and never had any fling what so ever. Best stuff I've found
    • Agree Agree x 2
  14. Kevin1
    Kevin1 Elite Member
    many years ago a friend of mine worked at David Brown Gears, in Huddersfield.
    He used to use some treacley stuff from work on his chain and his chain used to last forever.
  15. tuktuk
    tuktuk Elite Member
  16. nigelrb
    Not being a smart-arse (for a change:rolleyes:) but is it really white? I ask because of my white wheels;).
  17. tuktuk
    tuktuk Elite Member
    Yep. Almost like that white lithium grease stuff.
  18. Demmel
    Demmel Member
  19. CBRGav
  20. CBRGav
