What are these ?????
Discussion in 'Maintenance' started by Silverback, May 9, 2014.
  1. Silverback
    Silverback Member
    Spent the day spilitting the subframe to fit some Sato hooks, amongst other things. When I had finished and was tidying the gargage, I found these on the floor !
    Not certain they came from the bike but.............
    Does anybody recognise them as being part of a Fireblade?!!!
    They are not threaded inside.
  2. TheRamJam
    TheRamJam Well-Known Member
    They look like spacers
  3. Dave V
    Dave V Elite Member
    Spacers for the tank cover, well the one at the back certainly.
  4. Silverback
    Silverback Member
    Ah! Thanks, that's one of them sorted! What about the other ?!!!!!
  5. Mad Matt
    Spacers for mud guard or rear hugger??
  6. martinowen
    Something like above, they also have similar on the seat on the rr5
  7. arthurbikemad
    The thin one is used in a number of places, front and rear of tank shelter/cover etc, the thicker one is from the rear sub frame, if you look under the rear seat they are between the plastic under tray and the sub frame.
  8. Silverback
    Silverback Member
    Thanks boys!
  9. Black
    Black Active Member
    I like this game!:)
  10. lambchops
    lambchops Elite Member
    Yes me too, what's next?
  11. Silverback
    Silverback Member
    I have re-homed the spacer for the tank cover ! Thanks boys ! Can't be arsed with the other one if it means dismantling half the bike again !
    Now looking for longer battery connector bolts to make room for all the crap I have connected directly to the battery !!!
  12. arthurbikemad
    Any M6 - 1.0mm thread bolt should do :)
    And yeah those spacers at the rear need to be fitted before it goes back on :(
  13. Silverback
    Silverback Member
    Cheers Arthur !
    And..........hmmmmmm!
  14. The.kickboxer
    The.kickboxer Active Member
    I need some of the tank spacers, looked all over. What are they called? An ordinary washer and threadlock isn't quite the same
