  1. BeelzebubUK
    BeelzebubUK Member
    Fitted an R&G tail tidy which obviously took at least twice as long as I thought mainly trying to hide the wiring while not having it end up melting to the exhaust. That heat shield is a bit of an eye sore though now but I'm on the look out for an Akrapovic replacement exhaust anyway which will get rid of that.
    #11841 BeelzebubUK, Apr 13, 2025
  2. Gatsoburner
    Gatsoburner Active Member
    Heat up the snow shovel on the end can and it'll mould nicely :p
    • Funny Funny x 4
  3. BeelzebubUK
    BeelzebubUK Member
  4. bladey
    bladey Senior Member
    I got the seat cowl from Ali express, came within a fortnight, £25 incl tax/duty. Had to file a tiny metal tag off the bar that hooks into the lock and all well. Wouldn't know it from the original to look at and well worth the wait as opposed to the £300+ I saw for an OEM one.
  5. BeelzebubUK
    BeelzebubUK Member
    Fitted a Soupys adjustable lowering link to replace the original dog bone. Only lowered by about half an inch but it means I can get more of the meat of both feet down when pushing the bike rather than being on my toes. Need to take it for a ride this weekend just to make sure it feels good and I might lower the front forks to match.
  6. BeelzebubUK
    BeelzebubUK Member
    #11846 BeelzebubUK, Apr 26, 2025
    • Like Like x 9
  7. Dan Tyas
    Dan Tyas New Member
    How does the Yoshimura sound? Im on the lookout for a can for my 06 Blade, I think the Akrapovic might jus tbe a bit too steep costwise. Been looking at Delkevic, Dominator and Yoshi's
  8. Dan Tyas
    Dan Tyas New Member
    Fitted some new brake pads, replaced a few worn looking fairing bolts, had a bit of a rattle from the Heat Shield so I’ve dampened that and gave it a good clean. IMG_2266.jpeg
    • Like Like x 7
  9. Selmer50mark
    Selmer50mark God Like
    Fitted a Scorpion can last night
    • Like Like x 7
  10. BeelzebubUK
    BeelzebubUK Member
    First impressions is it's louder but not obnoxiously loud. Just more bass sounding especially on idle. I have a video I'll upload, just need to edit out the warming up and numberplate.
    Uploaded : https://streamable.com/4cn0d7
    #11850 BeelzebubUK, Apr 27, 2025
  11. Dan Tyas
    Dan Tyas New Member
    @BeelzebubUK & @Selmer50mark , When you've fitted your exhausts did you put any other heat shielding under the rear fairing? Ive seen that some exhausts come with them but the one i was looking at doesnt state anywhere if it came with some or not (Looking at the carbon Delkevic stubby pipe)
  12. Selmer50mark
    I left the original heat shield on and it fitted fine Screenshot_20250501_080824_Gallery.jpg
    • Like Like x 6
  13. Dan Tyas
    Dan Tyas New Member
    Thanks for the prompt response. Sorry for all the questions but did you have to remove/re-wire the servo? I watched a video of a geezer changing one on YouTube and he had to remove and re-wire the Exhaust servo.
  14. BeelzebubUK
    BeelzebubUK Member
    The Yoshimura came with a sheet of sticky backed heat shield material so the original heat shield gets removed. You have to cut 2x main pieces from the sheet and the leftovers are used to cover smaller gaps. Took me an hour or more to make sure I was cutting it right and then sticking it to the underside of the tail :eek:
  15. BeelzebubUK
    BeelzebubUK Member
    I removed both of the servo cables. You have to unhook them from the original exhaust before removal and then you can just get to the servo end and unhook them from there.
    I saw it from 02:30 in this video :
  16. BeelzebubUK
    BeelzebubUK Member
    This is mine without the original heat shield
  17. Dan Tyas
    Dan Tyas New Member
  18. Selmer50mark
    I basically did what the video showed up to the point of heat shield removal, didn't like his heat shield fitting process o_O
  19. BeelzebubUK
    BeelzebubUK Member
    Yeah I took my time and got mine to fit a lot smoother than his :D
  20. BeelzebubUK
    BeelzebubUK Member
    Decided to replace the rear indicators with some mini LED ones to tidy up the back and installed a new LED friendly indicator relay. They are eye watering bright :cool:
    These ones : https://www.amazon.co.uk/dp/B0CS2FKXMG
    • Like Like x 6
