What RR6 clip on torque and what clutch fluid?
Discussion in 'Maintenance' started by Muffking, Jun 30, 2015.
  1. Muffking
    Before I get my RR6 forks back it would be a good idea to know how much to torque up the clip ons by. Does anyone have a manual showing the values for the the front end?
    Also, I let the left bar drop down and the clutch reservoir is hanging upside own, so I'll need to bleed the system with what ever fluid is left.What clutch fluid should I use, or is topping up with a universal clutch/brake fluid good enough?
  2. SimonRR
    SimonRR God Like
    top pinch bolts 23nm, bottom ones 26nm
    I would bleed it just in case, think I used a DOT4 clutch fluid :D
  3. Barstewardsquad
    Clutch fluid same as brake fluid. I replaced all mine over the winter, think it was Motul RBF 600. Total overkill for the road/me really but I don't skimp on brake related. stuff
  4. Muffking
    Thanks guys. Just waiting for the call to pick them up and it's game on.
  5. KPH
    KPH Active Member
    Clip-ons ( Handlebar clamps to fork legs) - I had this recently on my 1000RR - the manuals states 26Nm as as I started, it felt too tight. I did a search and on the Renthal US site it stated 9 Nm for the clip-on clamp to fork bolts and 3Nm for the actual handle bar clamp.
  6. rb1000rr
    rb1000rr Active Member
    A good quality DOT 4 will do the trick worth changing it regularly too i do mine every 4 thousand when i service as it gets very discoloured by then was told by a Honda dealer it is normal and due to the size of the reservoir
