I press submit then get a page of writing, includings warning etc... Press back. Submit again then it just says its a duplicate post and I will got to original thread
Did it when I posted this thread and I got this Warning: curl_setopt_array() [function.curl-setopt-array]: CURLOPT_FOLLOWLOCATION cannot be activated when in safe_mode or an open_basedir is set in [path]/includes/bitly.php on line 141 {"errorCode": 0, "errorMessage": "", "results": {"http://1000rr.co.uk/showthread.php?t=4496": {"userHash": "Ig4T07", "shortKeywordUrl": "", "hash": "Ig4T08", "shortCNAMEUrl": "http://bit.ly/Ig4T07", "shortUrl": "http://bit.ly/Ig4T07"}}, "statusCode": "OK"}Invalid JSON-response on line 196 in /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php #0 /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php(382): Bitly->doCall('shorten', Array) #1 /var/sites/1/1000rr.co.uk/public_html/newthread.php(276) : eval()'d code(41): Bitly->shorten('http://1000rr.c...') #2 /var/sites/1/1000rr.co.uk/public_html/newthread.php(276): eval() #3 /var/sites/1/1000rr.co.uk/public_html/vbseo.php(1397): require('/var/sites/1/10...') #4 {main} Fatal error: Invalid JSON-response on line 196 in [path]/includes/bitly.php in [path]/vb/vb.php on line 287 #0 vb_error_handler(256, Invalid JSON-response on line 196 in /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php , /var/sites/1/1000rr.co.uk/public_html/vb/vb.php, 287, Array ([exception] => BitlyException Object ([] => Invalid JSON-response,[] => ,[] => 0,[] => /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php,[] => 196,[] => Array ([0] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php,[line] => 382,[function] => doCall,[class] => Bitly,[type] => ->,[args] => Array ([0] => shorten,[1] => Array ([longUrl] => When I post a new thread from my iPad,[history] => 1))),[1] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/newthread.php(276) : eval()'d code,[line] => 41,[function] => shorten,[class] => Bitly,[type] => ->,[args] => Array ([0] => When I post a new thread from my iPad)),[2] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/newthread.php,[line] => 276,[function] => eval),[3] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/vbseo.php,[line] => 1397,[args] => Array ([0] => /var/sites/1/1000rr.co.uk/public_html/newthread.php),[function] => require))), Code: => 256)) called at [(null):0] #1 trigger_error(Invalid JSON-response on line 196 in /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php , 256) called at [/var/sites/1/1000rr.co.uk/public_html/vb/vb.php:287] #2 vB::handleException(BitlyException Object ([] => Invalid JSON-response,[] => ,[] => 0,[] => /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php,[] => 196,[] => Array ([0] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/includes/bitly.php,[line] => 382,[function] => doCall,[class] => Bitly,[type] => ->,[args] => Array ([0] => shorten,[1] => Array ([longUrl] => http://1000rr.co.uk/showthread.php?t=4496,[history] => 1))),[1] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/newthread.php(276) : eval()'d code,[line] => 41,[function] => shorten,[class] => Bitly,[type] => ->,[args] => Array ([0] => http://1000rr.co.uk/showthread.php?t=4496)),[2] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/newthread.php,[line] => 276,[function] => eval),[3] => Array ([file] => /var/sites/1/1000rr.co.uk/public_html/vbseo.php,[line] => 1397,[args] => Array ([0] => /var/sites/1/1000rr.co.uk/public_html/newthread.php),[function] => require)))) called at [(null):0]
I had this when I started a new thread. I pressed refresh which cleared it. Submitted it again and it came up another twice. Then I had to delete two as it had posted them all
Yep Moily's right. Just posted a new thread on the iPad and got the same error message, but watched on the PC at the same time and it came up as per normal.
OK I think I fixed it. please let me know if it happens again. It looks like it was the auto post to Twitter plugin. I have now disabled it until I can fix it.
Ah, that'll explain this then... http://1000rr.co.uk/forum-suggestions-feedback/4497.htm PS the Twitter notifications were really handy for keeping up with the forum, so if you are able to restore them, that'd be very much appreciated..!
