Whirling noise front brakes
Discussion in 'General 1000RR Discussion' started by jamesd744, Mar 21, 2019.
  1. jamesd744
    jamesd744 New Member
    hi all
    Picked up my 2009 blade just noticed one thing when I go heavy on the front brakes there is a whirling noise.
    I took it back to the garage today and he said they work just fine, which they do. And the noise was just normal from vented disc’s.
    Anybody had a similar experience???
  2. Iain
    Iain Active Member
    What pads and disc's are fitted? Are they standard Honda ones?
  3. jamesd744
    It’s only done a 1000 miles so I guess so.
  4. nigelrb
    Never heard such a noise with any of my Blades.
    Makes me wonder that if it is only under hard braking, could one of the brake lines be rubbing against the tyre, OR, could it simply be tyre noise on the road? Any disc noise would usually be a high-pitched metallic sort of whine as a result of foreign matter (road grit etc) stuck in the pads - but that would rectify itself after a few hard stops.
    Also, is it ABS or non-ABS?
    #4 nigelrb, Mar 22, 2019
  5. sps170373
    Check all the disc buttons move freely if not it could be the disc rubbing the pads and when breaking heavy the metal warms up making the rubbing worse
  6. jamesd744
    Its non ABS
  7. jamesd744
    Hi sorry not to sure what disk buttons are
  8. Cream_Revenge
    Cream_Revenge Active Member
    Get the bike on a front paddock stand and make sure the front spins freely it should do at least 1 full turn.
    At 1000 mls I doubt the disc bobbins are gunked up but here is a video:
    I've had the noise you are talking about on one of my bikes after changing pads. Sometime certain disc/pad combos seem to cause the noise.
    I expect it's just new bike paranoia, I suffer from it every time I buy a bike.
  9. Cream_Revenge
    Sorry, 10 yr old bike with 1K mls!!! Did read that right ?!?!?!?!
  10. raphael
    raphael Elite Member
    I get that mate and it’s worse with the ebc disc/pads I put on compared with stock.
    Also get it a lot with Michelin tyres as your pushing them into the tarmac.
    If it’s not changing the way the bike performs I wouldn’t worry about it.
  11. Blade runner 1
    Blade runner 1 Elite Member
    I’ve had this with bikes and cars before, as said already it could be pad disc combination. Even though the bike has only done 1000 miles, it wouldn’t be completely uncommon for a dealer to change the pads especially if it’s 10 yo.
  12. nigelrb
    Please introduce me to such a dealer!!:D:D
  13. Blade runner 1
    Victor Devine Glasgow, replaced pads when my brother bought his 5 year old blade with 1500 miles on it. Yes I know you don’t often hear of dealers doing these sort of things, but it does happen.
  14. nigelrb
    That's magic, BL1. So rare to hear of those going 'above and beyond'.
    Now stored in my 'potential sellers' folder:D: https://www.victordevine.com/
  15. bazzer107
    bazzer107 Active Member
    If you have carried out all of the checks already mentioned by others above and found no issues as the bike shop said, it could just be normal noise you hear when a bike is being slowed quickly. You can hear the noise especially when stood at a track day or a race day, it's a noise I love.
    #15 bazzer107, Mar 23, 2019
  16. jamesd744
    Hi thanks all for the info...
    I have been out today and put nearly 200 miles on the clock i think it just how the breaks are they work great.
