Will a 2016 SP rear Subframe fit a 2010 Blade?
Discussion in 'Mods, Upgrades, Accessories and Products' started by TheMickster, Feb 3, 2017.
  1. TheMickster
    TheMickster Active Member
    Hi All
    Does anyone know if a 2016 SP rear subframe is a direct fit on a 2010 Fireblade, and can you use the 2010 seat unit/plastics/undertray etc?
    Cheers
    Mike
  2. Dave dunlop
    Dave dunlop Senior Member
    Yep subframe fits straight on as it uses all the same mounts, not sure about plastics but can't see Honda changing all the mounting points for the plastics as the only difference on the later models is a slightly wider rear tail unit. Seat is the same so don't think your have any dramas.
    Just be aware that you can't use pillion pegs on the SP subframe....
  3. TheMickster
    Thanks Dave,
    I probably should just get a standard subframe as the SP ones are a bit pricey for the plastics not to fit properly, but they do look better :)
    Or I need to find an accomodating breaker whos got one who could try the older plastics on it.
    Putting a track bike back on the road so, just collecting all the bits I need.
  4. si1000repsol
    Yes, here is my 2009 with the SP Subframe. It can be used with the 08-11 and 12-16 plastics.
  5. TheMickster
    Cheers mate, your bike looks sweet.
    Mine's got Ohlins front and rear and Brembos so will have a similar look, but with the 2010 style respsol rep plastics and carbon BSTs.
    Was tempted to go for the newer model plastics but managed to get hold of the original fairings for the bike.
    Just not sure if Black wheels will look wrong on a repsol :)
  6. Lozzy
    Its as wrong as going out with no knickers on :D
    I think at the very least you're going to have to put some orange wheel trim on ;)
    • Funny Funny x 2
  7. Dave dunlop
    Si.... does you rear preload adjuster not hit your hugger? perhaps it's just the angle of the picture:cool:but doesn't look like it has any clearance.
  8. Dave dunlop
    That's just plane dirty :D bit like your wheels:eek:
  9. si1000repsol
    Yes Its fine mate, its just the angle of the pic. It does look like its resting on the hugger
  10. 1000rrboyjay
    1000rrboyjay Active Member
    I have 2009 with SP tail and seat cowl. For straight on. Also, I know that the SP doesn't come with pillion pegs but I'm sure there's the holes to bolt them on if desired.
  11. sps170373
    I wouldn't put the pillion pegs on even if there are holes for them! As where Honda have machined holes into the subframe it essentially made the rear part of the subframe weaker and not able to carry a passenger! Hence why the SP comes without pegs and rear seat
  12. 1000rrboyjay
    Fair point
  13. GrumpyOldGit
    GrumpyOldGit New Member
    Hi guys can anyone confirm if you can fit a standard 1000rr rear subframe and plastics to the sp bike in order to have passengers.
    As it appears that the sp unit can be fitted to the standard I assume it can but wonder if anyone has already done it ?
  14. 1000rrboyjay
    Yes people have done it, but you can’t use pillion pegs
  15. GrumpyOldGit
    Ok but iff you can have pil pegs on the standard rr then why not ?
  16. 1000rrboyjay
    Because it’s been lightened with tidy looking holes. So it’s not designed for pillions
  17. GrumpyOldGit
    Think you are missing the point mate so the non sp version is designed for pillion use and my question was will that fit to the sp version as I would prefer the ohlins sus but want to still have occasional passengers
  18. 1000rrboyjay
    Oh sorry my bad, yes then! You could put standard on SP
  19. GrumpyOldGit
    Ok cool thanks that makes my decision much easier
