Woolich tuning package for sale 06-16
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Sep 15, 2017.
  1. vic_ster51
    vic_ster51 Active Member
    IMG_6765.JPG I have for sale a woolich racing ecu flash box and cable for sale
    Complete with cable for cbr1000rr 06-16 and cbr600rr 07-16
    All you have to do is just buy the BIN file
    £175 posted
    Details below or see There site
    https://www.woolichracing.co.uk/
    • USB K v3
    • USB Cable
    • Honda Harness Type 1
    • Bin File Definition in the Woolich Racing Tuned software
    Features available for Honda CBR1000RR
    • IAP Fuel Maps
    • TPS Fuel Maps
    • Ignition Timing Maps
    • QuickShifter (requires Race Tools)
    • Launch Control (requires Race Tools)
    • Pit Lane Limiter (requires Race Tools)
    • Race Shift Pattern (requires Race Tools)
    • Injector Balance Maps
    • Adjust RPM Limiters
    • Adjust Idle RPM
    • Adjust Fan Temperature
    • Exhaust Valve Opening Maps
    • Intake Flap Opening Maps
    • Disable Stock O2 Sensor
    • Disable Fuel Cut
    • Disable PAIR Valve
    • Disable Exhaust Valve
    • Disable Knock Sensor
    • Disable Steering Damper
    • Woolich Racing AutoTune
    • Real Time Engine Data
    • Diagnostics: Read and Clear Fault Codes
    Additional Bin File Definition Keys are required for each additional ECU's and can be purchased from within the WRT software.
  2. levin
    levin Active Member
    Does the bike have to be run on a dyno for a map to be loaded with this software or do you just buy a map from Woolwich, just wondering as I am thinking of getting my ecu flashed
  3. vic_ster51
    Hi. It's kinda like a power commander in sense your talking. They have couple maps you can load onto ecu no need for dyno. All done through the software on laptop etc. Same with disabling exhaust servo for example etc
    Obviously to fine tune and get perfect mapping can use a dyno. Good thing with this unit is does a hell of a lot more fueling ignition maps etc wise than a power commander and nothing is needed left on bike. You plug it in under seat do your stuff on laptop send to ecu unplug. Job done
  4. levin
    levin Active Member
    Ye I like the sound of it , being able to disable the fuel cut etc, just not sure of my local dyno tuner would map the bike if I supply the software and hardware, iv only ever got a pc mapped on the dyno before ,
    I will try give them a call tomorrow and see what he thinks, ecu flash works out as the same price as buying the hardware and dyno time
  5. vic_ster51
    He should be able too. Kind of the same as power commander with the mapping etc but yeah just can tune a lot more even the map you get from woolich way better and it's cheaper than pcv and does a lot more and no hassle to install etc
  6. Dio'sRR
    Dio'sRR New Member
    Any chance this is still available?
  7. vic_ster51
    No, sorry
  8. nigelrb
    Nothing remains for long with THE Vicster!!:D
