year confusion
Discussion in 'Maintenance' started by coxy, Jun 21, 2022.
  1. coxy
    coxy New Member
    Hi all, I am currently riding a 2006 Fireblade. I had some issues with the forks and have found that although its a registered 2006 everything is 04-05. I want to do a service but I'm not sure if I should be ordering parts for 04-05 or 06 onwards.
    Could some one possibly point me in the rite direction as to how i check what model should be ordering from.
    Many thanks
    Adam
  2. Coda
    Coda Active Member
    Registration date is useless, especially as DVLA made up the rules, got them wrong and then changed them several times.
    Short answer - if it's an 04-05 model, then that's what parts you will need to order.
  3. Barstewardsquad
    Quickest way to differentiate between 04/05 and 06/07 is the fairings.
    On 04/05 the main fairing is two parts with a visible horizontal join.
    This is an 04/05
  4. Coda
    Coda Active Member
    Oh that must have been when Honda decided to make fairing removal a PITA instead of simple :D
  5. Selmer50mark
    Selmer50mark God Like
    Different spring lengths and oil levels, ,,,,, that's all I see .
    But yeah as above order parts for 04/05 .
  6. coxy
    coxy New Member
    Makes sense.
  7. Barstewardsquad
    Yep that's an 04/05.
  8. Iain
    Iain Active Member
    Actually that is an 05!
  9. SimonRR
    SimonRR God Like
    I had a blue one like yours, reg was 06, but was a 05 model
  10. coxy
    coxy New Member
    Thanks guys, appreciate the help
