A better battery...
Discussion in 'General 1000RR Discussion' started by Patriotk11, Apr 6, 2025.
  1. Patriotk11
    Patriotk11 Active Member
    Hi
    I have a 2010 which I'm sure doesn't have ABS but the battery last season was not great. Slow starting, or flat if left for a day or two.
    I've trickle charged it all winter but it's no good.
    Can anyone recommend an uprated battery or at least one with a better start voltage or CCM.
    Thank you
  2. Lock
    Lock Active Member
    Noco lithium - seems good for me
  3. Boothman
    This is still going strong after 6 years
  4. Broadie
    Broadie Active Member
    Odyssey
  5. bonjo
    two options worth considering:
    good value AGM with 120CCA minimum and plan of replacing it every 2 years like a routine maintenance. Don't waste your money on yuasa.
    Alternatively an LFP battery. The ones recommended all have very small capacity, typically 2~3 Ah which is ok if you don't have parasitic drain or are patient with starting in cold temps (<3deg)
  6. Patriotk11
    I've gone rogue.... I've tried a Poweroad with the following spec
    New Factory Sealed Nano Gel Technology Batteries
    3 Year Warranty
    Technical Specification
    Voltage 12 Volts
    CCA 180A
    Length 113 mm
    Width 69 mm
    Height 105 mm
  7. bradt
    bradt Elite Member
    Motobatt
  8. Selmer50mark
    Yuasa, 12 years old and still cranking
